Orbi WiFi 7 RBE973
Reply
Extra ethernet input
JG37
Follower
Hi,
I need to plug in a 4th ethernet cable in the back of my router and there are only 3 input places.  Is there a splitter available and will this affect wifi speed?
JG
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
antinode
Guru
Re: Extra ethernet input
> there are only 3 input places. [...]
   An Ethernet interface is bidirectional; there are no input ports or
output ports.
> [...] Is there a splitter available [...]
   The usual device nowadays is called a "network switch".
> [...] will this affect wifi speed?
   It won't affect Wi-Fi speed, only wired speed, but not so you'd
notice, assuming that you get one with gigabit/s speed.
   I'd expect to be able to find a 5- or 8-port gigabit/s switch for
about $20 - $30.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 269 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
