ACJR
Jan 16, 2021Aspirant
FIRMWARE UPDATE
I can not update my firmware on my Nighthawk router!!
What firmware are you on?
Were is it failing in the process?
- ACJRAspirant
I'm trying to update to firmware version v1.4.1.68! I'm curently running firmware v1.4.1.50
- ACJRAspirant
Thanks for the info.! unfortunately it still did'nt update to the most resent firmware version
You don't tell us anything about what happens when you try, so it is anybody's guess as to why it doesn't work for you.
These things are often down to user error. But who knows?
