- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Feedback for R7000 New firmware 1.0.9.18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Feedback for R7000 New firmware 1.0.9.18
@Case850 wrote:
@IrvSp wrote:While I have empathy for all those with problem, I am basically not having any? Just want to add that to all the negative comments, as I'm sure there are others like me. Also to give hope to all that these V1.0.9.xx flashes don't damage the h/w, at leat not mine.
Your statement assumes that every R7000 ever made has exactly the same components. I would suggest there are internal differences.
@IrvSp wrote:
I do have one semi-serious problem. Windows 10's NET VIEW and the R7000 router do not get along. W10 dropped SMB v1.0 from the OS (unless already there and in use) but it appears that the NG firmware needs that to communicate with W10... not proven but it appears to be the case.
I have used ALL versions of V1.0.9.xx and gone back and forth with them working on the NET VIEW problem, but with all these flashes I've NOT experienced on drop on either the 2.4 or 5 Ghz channels.
To be more precise, the problem is with Readshare on the R7000 and Windows 10. If you had a dedicated NAS with SMB3 support there would not be a problem with the R7000 and Windows 10. I notice Readyshare on the R7800 supports SMB3 perhaps that is an alternative if you want to stay with Readyshare.
Yes, I'm sure different chips could be in different mfg. runs. Usually those might have a Vx designations, and the R7000 do not have that. Sure it is possible. But I've seen people that do have the problem state the R7000 they have is old too. However, it could be the root cause of the problem.
As for SMB1, since MS removed it from W10, then to me, that is a defect in the R7000 flash or if nothing more it should be stated in the README file, like the NG Arlo was.
However, there is a real problem within the Router, besides the SMB1. I use the USB connected drive to save files from the various PC and store video's for streaming on other devices (Smart TV, iPad's, etc.). I use DLNA clients to view those files with the R7000 being the server. Unfortunately at some point that DLNA Server disappears and I can't do that. The 'cure', reboot the router. I did discover at least on the iPad's that using either iOS Genie or a video program that is a Samba client they still can play the video's. So this is clearly an R7000 Flash problem. Maybe the SSID disconnects might cure this as well, who knows.
One other point, SMB1 not withstanding. For some 'odd' reason, my PC has SMB1's Automatic Removal and Server features enabled (was migrated from W8.1). It, and other W10 PC (without those features enabled) were able to use NET VIEW and it worked, probably up until Mid-Dec. (don't know for sure when it stopped working). What changed? I know it wasn't W10 V1709 as I had gotten that real early (Oct. 18th) and I am pretty sure it worked then.
What I did discover if I reboot the R7000, NET VIEW works fine. It seems that when I boot my PC or reboot the router (which starts out as the Master Browser) my PC will automatically try to be the Master Browser. It does get the device list from the router as the command works fine. However, once I shutdown the R7000 should know that and then become the Master Browser. That might not be working (bug?). Because the next time I boot my PC and it becomes the Master Browser, NET VIEW not longer works (error code 1231 which researching makes no sense) as I suspect it can't get the list of devices from the R7000 (we can argue who's bug that is?).
Since any W10 PC without SMB1 enabled could also become the Master Browser if another PC wasn't, that of course fails too. From that point on NET VIEW is broke until the R7000 is rebooted.
Why does that matter? Because I use Explorer++ (a Windows Explorer replacement I like to use instead) to open the NETWORK and allow me to drag files from any of our PC's to the READYSHARE folder I want. As I said, this was working probably until mid-Dec. when I couldn't see the R7000 shares in Explorer (on any PC). Rebooting the R7000 allows this to work until my PC was shutdown.
I do have a work-around though. NET USE still works and I can use it that way.
I've got a whole thread on this over HERE and I'm not the only one with the problem.
Getting a NAS? Maybe, but the R7000 did serve my purposes, and 'did' is the operative word.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't noticed any consistent wifi drops, with the router. But what I have noticed is an issue with QOS.
I've done a device specific QOS rule for my Xbox, and have it set to the highest priority. I think filled in the "Uplink" section with my max upload speed of 5mbps, (4.72 mpbs if running the auto speed test on the page) This setting also seemed to throttle the download speed for the xbox, to the same speed as what the uplink was set to.
I've gotten around the issue by setting the "Uplink" speed to 50 mbps. which allows the xbox to get the max down and up speeds I'm supposed to get.
Also I think it's kind of odd that the router main page would let me know that there was a new firmware available, but in a beta version. One would think unless it's fully tested it wouldn't get pushed out that way.
Just my 2 cents.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had similar issues with QoS with multiple devices so I just disabled it. I'm not worried about my speed anyway since I have plenty. (100mbps).
I also setup all my streaming devices on LAN as much as possible or 5ghz. My phones and laptops also use 5ghz. Low priority devices and my kids tablets and guests run off 2.4ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I'm running the .18 firmware and whilst I'm having ZERO drops, the speed on 2.4ghz is atrocious. I'm running 5ghz on most appliances and phones to get by but the range is obviously effected.
I tri d turning off the 20/40 coexistence setting which is supposed to speed up 2.4ghz and guess what...it gets worse.
So I'm really stuck here. Seriously considering putting tomato on it unless Netgear can give any update on what's actually happening?
I know another firmware was given to some via PM but I'm not trying that unless it's released as a Beta at least.
Any news..ever..anyone??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any new updates NetGear?????
- Mark as New
- Bookmark
- Subscribe
- Permalink
@solag wrote:Any new updates NetGear?????
Funny that people still ask this. After 585+ messages on this post and no communication from them, do you actually think they monitor this thread anymore? It is clear that Netgear doesn't care about their customers or fixing this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Haven't you when them off?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
no bug fix, no time line, nothing from offical NG site till now.
Don´t think that is a normal behavior for an US company . Bur for sure not the best reputation to get a bigger footprint in Europe.
Anyhow .. I think I have to swap to Vtex or Tomato. But just in case... do someone have any expirience to go back to original NG SW?
BR
Michael
- Mark as New
- Bookmark
- Subscribe
- Permalink
BR
Michael
My advice would be XWRT-Vortex, it is rock solid stable and easy to use. There is a way to go back to stock, but I'm pretty sure you won't go back once installed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Case850 wrote:These Netgear "Routers" are not pure routers but a hybrid of barebone features that are contained in many stand alone devices. Modem/Router/Ethernet Switch/Wirless AP/NAS.
It is the failure of the 2.4G Wirless on the R7000 that is the focus of this thread. It is the part that is currently consuming a great deal of time and energy.
The NAS features which Netgear support via the suite of Readythis and Readythat is a completely separate issue. It belongs in a separate thread which you had already started, but now have decided to post here.
Sorry, I beg to differ... I thought the issue WAS due to this firmware, and I did post that info WAY UP this subject. See Page 5,
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd support XWRT-Vortex as well. Switched to the current version and have had no drop offs. To be fair I haven't tried Tomato so I can't make any statements that 1 is better than the other. I'm just happy to have a stable router at this point. Probably won't go back to NG FW unless I see some happy customers on this thread. Not sure I'd buy a NG when current router craps out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, all customers will be happy when NG give them a stable firmware, still I'll be on XWRT-Vortex. Never go back as it is very stable and has a great GUI. Easy to setup and some nice features.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest update on R7000 as of 4PM (Pacific Time), January 12, 2018.
We are continuing to work through the disconnects noted by the community by engaging with some of our users. We are working on a firmware version that is currently being tested in our lab and is being monitored over the next few days. We would also encourage other user in the community who are experiencing the disconnects on the 2.4GHz band and want to help through this process to reach out to us to work together.
Thanks, Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sohey, thats a very quick update after weeks of problems and no feedback!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
For those of you that have flashed your firmware to XWRT-Vortex, have you noticed any difference (increase or decrease) with the range of both 2.4G and 5G compared to the NG firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
To answer the question about range, I will say in my situation I am noticing an increase in signal strength. 5GHz in particular has a stronger signal than it used to, and my tenants on the 2.4GHz guest network say their speeds are faster. Hope that helps!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have patience, they will release a new version. Or if you problem is so big wrote a personal massege to JamesGL or other admins in this forum with describing of you problem. For me i didn't have any issues with Wi-Fi connections. I have only a problem with VOD services and IPTV with version 1.0.9.18 and wrote to JamesGL via personal messages. Support gave me beta version with fixes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Rikardo007 wrote:For those of you that have flashed your firmware to XWRT-Vortex, have you noticed any difference (increase or decrease) with the range of both 2.4G and 5G compared to the NG firmware?
In default setting it is pretty much the same but as it is rock stable without dropouts it feels much better. In XWRT-Vortex you can also adjust the TX-power. Default setting is 50% and can be increased. Be aware that you might shortened your hardware lifespan.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It’s them:
Seriously, I don’t have any Google cast devices and don’t have any problems with my R7000. Not on 2.4 or on 5 GHz with fw 1.0.9.18. Stable for many weeks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you configured your R7000 relatively by default you probably haven't enabled BWDPI yet. Go to Tools->Other Settings and scroll down to Asus features. Enable BWDPI to Yes and click Apply Settings. Reboot the router now. After booting log in to the router and you have AiProtection, Adaptive QoS and Traffic Analyzer added which are very nice features.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had to jump ship I'm afraid. I need stability on my Wireless setup - Tomato installed. Let's see how this goes...
