- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Feedback for R7000 New firmware 1.0.9.18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Feedback for R7000 New firmware 1.0.9.18
In case someone missed this post (sounds promising):
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the previous post could be a winner, or as mentioned in another post:
Switch off 5Ghz and QoS and 2.4Ghz is stable again.
(I won't bet you a case of beer on these solutions, but what the heck, give it a try).
Even better: do the actions in the previous post, switch off 5Ghz and QoS, pray to the god of your liking, switch on all the lights in you house, disconnect the dishwasher......and then see what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did this and it didn't work. I then also turned off the guest network and now running for 2 days with no problem.. Again, not a fix but at least I am stable until it is resolved. (?? Considering getting one of R8000 refurbs since I too only get about 45 mbs on my wifi will getting 420 on my wired! ??)
- Mark as New
- Bookmark
- Subscribe
- Permalink
OFF TOPIC: what app are you guys using for mobile wifi throughput. Not loving the apps I've found.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just downgraded to 1.0.7.10_1.2.3 and I went from 95Mbps to 350Mbps ! And no more lost connections !
I agree it is not great because of security issues .... but it shows that the driver could be fixed !!!!
Come on Netgear ... do something !
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ugh. I woke up to no 2.4G devices connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hard to say exactly. Around 48 hours. Nothing valuable in the stats or logs. No errors, no failed connection attempts, no packet loss on the link. The lease did renew at 4am last night. It looks like all the 2.4G devices (and only 2.4G devices) didn't reconnect. Some are DHCP and some are reserved. A simple reboot solved the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't use my 2.4ghz much except for game consoles but this has been happening to my network for months now on the 5ghz band. And It also keeps dropping one of our printers (wired Brother) as well. wake up or suddenly lose internet while using it on wifi devices and tunr wifi on and off on devices then they can no longer get an ip even though they are set static. I do use ACL and at times the guest network also does not work as people get thrown in the ACL odd. Firmware is V1.0.9.14_1.2.25
EDIT: I repair networks and pc's as my job so I recomend this router personaly a lot if they need the features it provides and I have much experience with it and now this can no longer be a thing if NETGEAR does not come clean and explain what they have been doing to address this and what is even changed in the change logs vs just saying fix's.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Like others, I continue to have the 2.4 wifi drop every few ~hours~. I have reset, updated firmware, adjusted settings, etc...but the issue still persits. I have had my router, and it has worked great, for years...but in the last month+ this issue continues to plague my network. I depend on my Netgear equipment to keep my home network running smoothly, but the poor response and massive number of frustratingly invested hours is pushing me to leave Netgear. Additionally service/help/support has been more about distracting or ignoring me instead of treating me like a valued customer.
Please fix this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems my posts keep disappearing... Please disable the IPv6 status output via console. It spams the serial console while I'm trying to do work.
[85164.750000] connection 1397 change state to closing. [85164.820000] connection 1442 change state to closing. [85164.850000] connection 1393 change state to closing. [85164.940000] connection 126 change state to closing. [85165.080000] connection 8 change state to closing. [85165.120000] connection 1407 change state to closing. [85165.160000] connection 1455 change state to closing. [85165.550000] connection 1484 change state to closing. [85165.580000] connection 960 change state to closing. [85165.610000] connection 132 change state to closing. [85166.280000] connection 1515 change state to closing. [85166.480000] connection 1512 change state to closing. [85166.750000] connection 1537 change state to closing. [85167.190000] connection 1540 change state to closing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems I have joined the ranks of the 2.4G disturbed. All my 2.4G devices simply disappeared from the connected device's screen, so I assume the router tables also. Nothing to tell what went wrong. no errors. no log messages. A simple reboot fixed the problem. Last time I thought it was related to renewing my lease. Not the case this time. Also checked my modem logs. The ISP side was stable when this happened.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
They may all be gone for the holidays now. Perhaps will get some love in January.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One more quick thing... Inside string_table_r7000 for English.
cpu_loading="CPU Loading"
Should be
cpu_loading="CPU Load"
It looks so out of place on the web panel having it saying "loading" instead of "load".
- Mark as New
- Bookmark
- Subscribe
- Permalink
My opinion (free and worth every penny). I'm seeing the frustration with Netgear on this firmware release. I'm a Netgear fan. I also have a 5 camera Arlo system at home. We have had a couple firmware hick-ups on the Arlo side. I suspect that the engineering group doesn't communicate all that well with the support team. My experience is a new rev will show up soon without us knowing anything new.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Further to my post of 2017-12-19 11:01 PM.
I continue to have have instability in the 2.4Ghz band. The longest period of stability I had was roughly 36 or so hours. So continuing to tweak as I have devices that use the legacy tech. What for me is strange is that the devices have an IP address so are connected to the Router but can't move past it. They also don't show up in the router menu for attached devices. Hopefully a permanent solution will be found soon so we don't need to reset/reboot the router regularly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also experiencing the 2.4GHz drops. I upgraded to 1.0.9.18_x code with Smartconnect enabled. The problem did not go away. I disabled Smartconnect and separated the 2.4/5GHz SSID's. I've now been running with Smartconnect disabled for 4 or 5 days and the problem persists.
I have to reboot my router 2-3 times a day to get my 2.4GHz devices back on the network. I've moved any device that is 5GHz capable to my 5GHz SSID, but that doesn't help with all of my 2.4GHz-only devices (e.g Nest Protects).
This problem existed under the previous code release. I'm very disappointed that Netgear hasn't corrected the problem. If a solution doesn't get posted soon, I will need to try Advanced Tomato.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm experiencing the problem since last 2 versions of code. I've had the same password on my 2.4GHz and 5GHz SSID's for years. Has anyone seen that changing the passwords fixes the problem? I'd prefer not to experiment, since changing the passwords will be a real hassle for many of my IoT devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to add to the 2.4Ghz story. I have had many issues with 1.0.9.X past .6 branches of code as have been well documented in other threads. Most of my issues were speed related but have been fixed in .14 build. However all along I haven't had any issues with 2.4Ghz at all. I only have thermostat and sometimes iPhones on it (they sometimes hop from 5GHz). Never had to reboot router due to lost communictation for a month or longer. One thing I wanted to share in case it matters is my SSID / Wireless setup.
2 different SSID for 2.4 / 5 Ghz
Same WPA2 PSK
Smart Connect Disabled
Guest SSID Disabled
20/40 MHz Coexistence Enabled
My R7000 is over 3 years old also. My modifications from factory default are simply SSID and password config. I leave everything else as is. Just wanted to share in case it helps someone else. I installed .18 tonight and will see if my experience changes. Good luck to those having 2.4 GHz issues.
