Orbi WiFi 7 RBE973
Reply
Firm Ware update R8000P
PhilKr
Follower
I saw some reviews that indicated that when you updated the firmware, users experienced problems. Since my router is new, it indicates that there is an update available for my router. an agent told me not to update unless I was online with support. I don't understand this. Has anyone had this issue.
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 4
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Firm Ware update R8000P
You should be fine to upgrade the firmware just make sure you do it with a PC directly connect via wired ethernet and not with a device connected via the wireless.
DarrenM
Message 2 of 4
All Replies
DarrenM
DarrenM
Message 2 of 4
gl-moore
Initiate
Hi,
No matter f I upload firmware or using the auto method  the fireware is not updating...  once rebooted it shows same version.
Hardware Version R8000P
Firmware Version V1.4.0.10_1.2.14
GUI Language Version
V1.4.1.24_2.1.46.1
Message 3 of 4
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2540 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
