Orbi WiFi 7 RBE973
Reply
Firmware 1.0.9.88 R7000 shows duplicate devices
DaBuddah
After downloading this firmw5 version I noticed the on the nighthawk app in device manager that there seems to be a lot more devices connected then there actually is. For example I only have my tv connected to the Ethernet port but it shows it connected to the 5ghz Network and it's showing 22 other devices connected to the wired ports.
I assume to is a bug?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 17
Accepted Solutions
BK77
Re: Firmware 1.0.9.88 R7000 shows duplicate devices
I finally got a chance to take the network down for a while and was able do a factory reset of the AC1900 R7000. I updated the firmware to 1.0.11.136_10.2.120 from a computer connected to the router via ethernet. So far everything is working. I will post if problems develop.
Message 12 of 17
All Replies
Guru
Probabably an incompatibility with the NH app and use of older FW.
Message 2 of 17
Guru
why not update to the 1.0.11.134 version of firmware?
https://www.netgear.com/support/product/r7000.aspx
Message 3 of 17
DaBuddah
I had the router check for new firmware and it said there is nothing new 😞
I also downloaded a new update for the app but still seeing the same situation. Logged in and out of the app, rebooted the router.... same.
Message 4 of 17
Guru
The auto-update process for the r7000 has never worked that great.
You can manually update through. I'd recommend doing it through a hardwired connection for best results.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Message 5 of 17
BK77
I recently updated my R7000 AC1900 firmware from V1.0.9.64_10.2.88 to V1.0.11.134_10.2.119. It worked for two days and then the wifi connected devices would no longer communicate with each other. The devices were all on the primary network not the guest network. The wifi speed did not make a difference. Also found the router browser interface would not work correctly sometimes. After combing the internet for hours I gave up and I went back to V1.0.9.64_10.2.88. Everything is working well now but I really would like to keep up with the latest firmware. Any help is appreciated.
Model: R7000|AC1900 Smart WIFI Router
Message 6 of 17
Guru
Is Smart Connect enabled?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many
Message 7 of 17
BK77
FURRYe38 thank you for your response.
A factory reset and setup from scratch has NOT been performed since last FW update. If a factory reset is performed can the router settings be saved before the FW update and then restored after the factory reset?
The internet service provider is Verizon FIOS. The ethernet cable goes from the R7000 into an ethernet port mounted on the wall which I assume is connected to the ONT outside.
Smart Connect IS enabled.
Channels are Auto (2.4Ghz) and 153(5Ghz).
There are twelve other wifi access points in the area.
Message 8 of 17
Guru
Yes, you can save a back up to file then reset. I recommend trying a fresh setup from scratch first to see if the problem appears before loading the backup config from file.
Message 9 of 17
BK77
I will try a fresh setup from scratch first. It may be a while as I need to do the update when the network can be taken down. I will post the results.
Message 10 of 17
Guru
Any progress on this?
Message 11 of 17
BK77
Message 12 of 17
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 13 of 17
BK77
So far so good. FURRYe38 thank you for your help.
Message 14 of 17
Guru
Message 15 of 17
DaBuddah
So to confirm, you were able to fix the situation I see with devices showing as connected when they are not like on wired, shows 6 devices when in reality there is only one device plugged into the access point/router?
Message 16 of 17
Guru
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 3841 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
