Orbi WiFi 7 RBE973
Reply
Firmware update
jmaurek
Follower
Firmware update
When  I check for New Firmware using the APP on my phone, I get this message.
There was a problem checking for firmware update.
When I tried to download the firmware...
The ZIP file contains
"Release Notes"
Message 1 of 3
Guru
Re: Firmware update
When you download it, it should download as a zip file. Extract that file.
Then follow the manual update option.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Message 2 of 3
Guru
Re: Firmware update
the recovered file fragment is just how windows identifies it. Its in a .chk format that you upload to your router.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 694 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
