Orbi WiFi 7 RBE973
Reply
General Router - top 5 things to setup? - Router Guru's ??
Just picked up an AX6 router (AC4300) - and I don't really want to go through the 160 page manual page by page..
If there are some router guru's out there, what would you suggest I do (if anything) as to changing the basic settings on my working router. This doesn't have to apply to this exact router, but general info would be helpful to many I think. QoS? Setting channel numbers for 2.4 and 5.8 frequency bands? ... I know I'm missing a lot and your advise would be helpful.
Thanks
Scott
Message 1 of 3
Re: General Router - top 5 things to setup? - Router Guru's ??
You are trying to fix a problem of some sort?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Message 2 of 3
Thanks!! Reposted in the section you suggest.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 405 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
