Orbi WiFi 7 RBE973
Reply
Guest Access 2.4ghz Enabled but not visible since new firmware
oszy
This week I installed firmware version V1.0.2.84 (the most recent).
Since than my guest access 2.4ghz is still enabled but not visible (so neither accessable) on android nor apple devices. I've had this guest access as long as I have the nighthawk.
I've turn it off, renamed it, but no luck at all.
I did turn on a 5ghz Guest Access, which does work.
Anybody any idea how to fix this?
thanks
Oscar
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
microchip8
Master
Re: Guest Access 2.4ghz Enabled but not visible since new firmware
Roll back the firmware?
Latest one has multiple issue and it seems the further we go, the more broken the firmware for the R7800 gets.
Message 2 of 4
oszy
Thank you for your answer,
Is there an easy way to do this?
Message 3 of 4
microchip8
Master
Sure. Use a wired PC and go to http://routerlogin.net or http://192.168.1.1 then flash a version from here: https://www.netgear.com/support/product/r7800.aspx#download (click on the + sign for other versions)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 462 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
