Orbi WiFi 7 RBE973
Reply
HP MFC M29 WiFi keeps blinking
Bagchip
Hi -I just installed Nighthawk. While it connected without problem to my computers and phones, but it CANNOT DO SO WITH HP MFC M29w printer. Any suggestions?
Thanks
Message 1 of 6
Accepted Solutions
Bagchip
Re: HP MFC M29 WiFi keeps blinking
I was able to get it work with hp help. Thanks
Message 5 of 6
All Replies
Guru
What model router did you install?
Contact HP support for help and information regarding there printer as well.
Message 2 of 6
Bagchip
AX5200 model
Message 3 of 6
Guru
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Might disable AX mode on 2.4Ghz to see if this helps any.
Thank you.
Message 4 of 6
Bagchip
Message 5 of 6
Guru
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1472 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
