Orbi WiFi 7 RBE973
Reply
[Help] r7000 router 5Ghz light (LED) not lit out on the router
ksw210
Hey guys, my r7000 router 5Ghz light is out on the router
It show 5Ghz is enabling in Netgear genie, and i'm not able to search it in wifi...
is it software / hardware problem.... i gotta need some help here
PS: I'm using orginal most updated firmware (as it said)  and settings,
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 7
Accepted Solutions
Wolf_666
Luminary
Re: [Help] r7000 router 5Ghz light (LED) not lit out on the router
Message 2 of 7
All Replies
Wolf_666
Luminary
Try a reset and flash the firmware again. There is a beta out right now.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Best-Firmware-for-Nighthawk-R7000/m-p/106243...
Message 2 of 7
ksw210
do u meant V1.0.6.40_1.1.90? Sure! I will try it out later.
hope it works
Message 3 of 7
Wolf_666
Luminary
Yes, I am using it and it works fine.
Message 4 of 7
ksw210
U had same issue as well?
Message 5 of 7
Wolf_666
Luminary
I did not ever have any problem with my R7000, both with stock firmare and DD-WRT. Now I only use stock FW because it is more reliable on Wi-Fi performance and because I use my R7000 as an AP only.
Message 6 of 7
ksw210
Man i made it.
1) upgraded Firmware
2) restored to default setting
Works for me, Appreicate for the reply 🙂
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4215 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
