Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I change my wireless network password Netgear?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-05-16
11:42 PM
2021-05-16
11:42 PM
If a user is unable to log in to the routerlogin.net window, the first thing he should check is the login credentials that he typed on the Netgear router login window. The default username is “admin” and the default login password is “password” of the login window of a Netgear router. Make sure you hold the Shift key when you want to type an uppercase letter and release the shift key when you want to type a lowercase letter. Any fault while typing the login password may bring failure in the login process.
Model: A6210|AC1200 High Gain WiFi USB Adapter, AirCard 307U (all others)|AirCard USB 307
Message 1 of 1
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
