Orbi WiFi 7 RBE973
Reply
How do I deploy a VPN to my home network?
Sailordude9980
Good Morning Netgear Community
I am setting up a VPN for the first time on my home network.  I have a question about deploying the VPN service to other devices on my network.
Can I setup Open VPN on just the router?  I was hoping I didn't have to install / setup on each one of my devices (laptop pc etc)
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 5
Accepted Solutions
kirstendunst888
Re: How do I deploy a VPN to my home network?
Yes you need to configure your router to run VPN on any device. Here's a simple guide for you  https://www.purevpn.com/router-vpn.php
Message 5 of 5
All Replies
Retired_Member
Not applicable
The help menu pulldown in the router suggest (to me anyway) it's required on any device which will be used to remote in not each device on the local LAN.
Message 2 of 5
Sailordude9980
Ah, I missed it. Thx. I hope you werent meaning ypur post to be sarcastic.
Message 3 of 5
Retired_Member
Not applicable
Not at all, If meaning to be sarcastic I would leave No doubt about it.
Message 4 of 5
kirstendunst888
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3537 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
