Orbi WiFi 7 RBE973
Reply
How to Update R7000 from 1.0.3.68?
whitedp
Tutor
Hello. A friend has an R7000 router currently still using firmware 1.0.3.68_1.1.31 and I tried to update it via the control panel's Check for new firmware mechanism. All it ever did was say "trying to to connect to Netgear Server". This happened on multiple attempts and nothing else. I am presuming that this might have to do with the installed firmware being too old. Any suggestions/tips on how to get this done? I am very concerned about bricking the router or loosing existing configuration information as I have to do the updating remotely. Thanks
Message 1 of 4
Guru
Re: How to Update R7000 from 1.0.3.68?
Message 2 of 4
whitedp
Tutor
Thanks. So there is no problem in trying to make the jump from 1.0.3.68 all the way to 1.0.11.136 in a single bound? Again, I am very concerned about possibly bricking or otherwise messing up the router since I am doing it remotely for a very non-technical friend. Thanks
Message 3 of 4
Guru
Should not be any problems if they follow the instructions.
Again use a wired PC and web browser. MS Edge in Windows or Safari for Apple.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 471 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
