malevich54's avatar
malevich54
How to block JUST outgoing traffic from device?
The device manager allows me to block all traffic on a device. I want to just disable all outgoing traffic, not incoming traffic. Where is the option for this? Thanks.
    • That appears to be the case. Is there any way to just block outgoing traffic from a specific device, or am I SOL here?
      • > [...] block outgoing traffic from a specific device, [...]
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual.  Read.  Look for "Block a
        Service or Application From Accessing the Internet".  Does some
        combination of Block Services, all ports, Only This IP Address, and so
        on do what you want?  You'd need to use something like Address
        Reservation to fix the IP address of the target device.
           It might help if you described the actual problem which you are
        trying to solve.
