Reply
How to change the TTL on outgoing LAN traffic
TateTate
Follower
Is there a Telnet command or any way to change the TTL on outgoing packets?
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
microchip8
Master
Re: How to change the TTL on outgoing LAN traffic
You can enable Telnet at http://192.168.1.1/debug.htm
I do not know if you can change the TTL.
Routing: NETGEAR RAX43 - Firmware: v1.0.15.128 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2)
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1884 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
