- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to force the client to roam at a specific signal
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to force my phone to roam from one R9000 to another. I read about 802.11v protocol, and I understood that the AP can send the phone a signal to disconnect from it along with the list of recommended APs. Is there a way to forge the disconnection signal?
Currenly, I have two R9000 APs and one ASUS Rog phone. Do I have to install a controller, or do the APs communicate directly?
Thank you,
Ali
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF your using the R9000s in AP mode then they are connected via ethernet. Wireless is using separate signals and channels. They do communicate wirelessly between each other.
You'll need to contact the Mfr of the phone to ask them how it handles connections, wifi signals and it's roaming features.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to force the client to roam at a specific signal
Its up to devices to pick and choose where they connect and how they roam. Something that can't be configured on NG routers.
You can help some by lowering the transmit power on the routers from 100% to say 50% may help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your answer. Can I use a WLC to enforce the phone to roam?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something to check to see if it works for you or not. Contact the Mfr for that product and ask about it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was reading through your setup, and I noticed that you are using a modem as well as a wireless backhaul. Can we replace the modem with a backhaul as the role of the backhaul is to connect with the core network?
Again, thanks for your available time replying to my questions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What Brand and model modem do you have now?
To get backhaul support you'll need a MESH system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually I am interested in doing research in this area and as you already notices, I still need too much to understand. My only goal is to force the phone to roam according to my order and not according to its implemented algorithm.
Going back to your question, I am using two Nighthawk x10 AD7200 smart WiFi routers (Model R9000) and an ASUS ROG phone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What Brand and model ISP modem do you have?
Using Two R9000 doesn't offer MESH or wireless backhaul support.
NGs MK series or Orbi systems offer wireless backhaul support:
https://www.netgear.com/home/wifi/mesh/
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am not using any Internet provider. All what I am doing is to find a way to move the phone from one AP to the other forcefully. The two APs do not have an access to the Internet.
In my deployment, I do not require backhaul support.
I have another question: how are these APs communicating when the phone is roaming between them? Can the two APs communicate wirelessly to move the already established session between them? Or should exist a WLC to handle the session handover?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok deal, thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
