- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to remove antennas from R7000?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an existing Mesh network (not Netgear devices) and I am replacing a dead Router with a new R7000. I use ExpressVPN, thus the R7000 has ExpressVPN's firmware in it. Accordingly, I do not use or need the R7000's WiFi at all. The R7000 is solely the VPN device between the fiber and Mesh WiFi network. I want to remove the antennas since the R7000's WiFi is always off, 24/7.
Does anyone know the trick to remove the antennas? I could take the router apart and unplug the 3 internal antenna cables (as links to photos found elsewhere on this forum show), but this does not remove the antennas from the rear of the chassis - which is my goal. I think a hack saw will be my eventual method to remove them.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to remove antennas from R7000?
You can't remove those. They are permanently attached. I would recommend just leaving them. Turn then down so they are not in the up position.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK. Thank you for the reply!!
(A hack saw it is. : )
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would not be advised to do that. Your router though. 🙄
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think it you can remove the anteena. However, if there is any must share it with me
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those type of antenna connectors are not removable. They are permanent. I guess NG came out with two versions of the R7000 as my R7000 I have has the removable un-screwable antennas. I guess later versions of the R7000 were made not removeable.
