Orbi WiFi 7 RBE973
Reply
How to set up my pre-owned AC1900 router
JimmyFung
Follower
Can anyone help teaching me how to reset & re-register my pre-owned AC 1900 router ? I just brought it lately. QR code has been use by first owner, cannot re-register it .
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Guru
Re: How to set up my pre-owned AC1900 router
You don't need to register it to use it.
Start with a factory reset.
Push and hold reset for 7-15 seconds while its powered on.
then install using a pc/laptop or the browser on your phone. Don't use the app. When you start the install proces it usually says "use the app/get it here" and then at the bottom of the page there should be a link for "i don't have a phone" or something simlar. uset that process.
Its much easier/faster.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 404 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
