Reply
How to update firmware in R8000P bridged (not primary router) router?
aragonl
Follower
My current configuration is:  Modem to Model RAX45 (AX4300), then using bridge function to Model R8000P (AC4000).
Is there a method to update the AC4000 firmware while in the above configuration?  I can't add the AC4000 to the app without removing the AX4300.
Thanks!
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Kitsap
Hero
Re: How to update firmware in R8000P bridged (not primary router) router?
Strongly recommend you DO NOT update the firmware of anything via an app.  Way too many problems arise as a result.  Specifically corrupt firmware.
If you feel you need to update the firmware, I strongly recommend you do so manually via an ethernet connection cable to the device and using a web browser on a computer.  If that is not convienent from a location standpoint, disconnect the device, move it to perform the update and then move it back.
My setup: Comcast -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.67HF)
Message 2 of 2
Discussion stats
  • 1 reply
  • 237 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
