Orbi WiFi 7 RBE973
Reply
I have a model Nighthawk X10 and Nighthawk X65 Model EX8000 I can not get extender to hookup
bhery1110
Follower
I have just had this problem since I updated my firm ware and software.  I tried to connect and I get the message to look for the net 65ext.  I do not show that.  I have unpluged both the router, modem and extendern and ten restarting first the modem then the router then the extender.  that did not do any good. I am lost and not a IT person or have any experience.  can anyone suggest what to do.
Message 1 of 2
Guru
Re: I have a model Nighthawk X10 and Nighthawk X65 Model EX8000 I can not get extender to hookup
do you have the EX8000 setup as a mesh device?
If so, it uses the same ssid as the router and you won't see a "ext" device.
Maybe after the update, it got switched to mesh mode (onessid is what its called)
What are all the led's on the ex8000 showing?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 301 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
