Ilja's avatar
Ilja
Follower
Sep 19, 2022
I reset the router and it worked fine for 2 weeks, now it starts again
I have the same issue. I reset the router and it worked fine for 2 weeks, now it starts again.. very inconvenient as every devise is not connected anymore, need a solution for this! I have an R7800
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Same as as who/what?
    I can't see any history in this discussion. And this seems to be your first message in this community.
    Did you hitch a ride on an old conversation and forget to add any details?
    What starts again? The issue you have not told us about? The router?
    Which devices are these? They are not connected to what? Wifi? Wired Ethernet?
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
