Reply
IPHONE 13 pro Max dropped call issue
edwardstuff
Follower
Using Netgear X6 R8000
Netgear EX7700 extender
my iphone 7 never had a problem, always used Smart Connect
Now I always have Issues especially with sending pictures, take forever to send. Calls are always losing clients the ability to hear me, I can hear them though.
All my computers are wired.
HELP
Ed
Message 1 of 3
Guru
Re: IPHONE 13 pro Max dropped call issue
are you using icloud relay or private mac/ip address?
those can cause issues?
if you unplug the extender, do you still have issues (trying to determine if extender issue or router issue)
What firmware is on the router?
What modem/gateway is the router connected to?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Guru
What Firmware version is currently loaded on the router and extender?
What is the distance between the router and extender? 30 feet is beginning distance.
What is the SQ feet size of the home?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 352 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
