lecole71's avatar
lecole71
Follower
Nov 16, 2021
Ideal modem to use
Hello,
I am inquiring about which modem to get with my R6700AX router.  My ISP max speed is 200 Mbps.  Can someone suggest a suitable modem.
Thank you
1 Reply
  • plemans's avatar
    More importantly is finding one that is compatible with your service.
    I'd check with your isp on compatible models for your speeds and isp.
