Orbi WiFi 7 RBE973
Reply
Insight basic portal issue
tosh30
I have a Guest SSID that works as an open network.  When I turn on captive portal, that works too.  When I turn on and add a Redirect URL, the redirect does not work at all.  Any issue with this field?  I have a website that worked when we were using Comcast's WiFi pro, and is still works now.  Is there a bug with this field?  Is there a specific format, like leave out https:// or www?  Thanks for any suggestions.Screen Shot 08-12-21 at 02.24 PM-2.png
Model: WAC540|Insight Managed Smart Cloud Tri-band 4x4 Wireless Access Point
Message 1 of 5
Accepted Solutions
tosh30
Re: Insight basic portal issue
I'll repeat the process in the Insight community page.  Marking this as Resolved to close it here.
Message 5 of 5
All Replies
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
or even here:
NETGEAR Insight Network Management - NETGEAR Communities
The WAC540 isn't much like the routers covered in this section and Insight is its own thing.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 5
tosh30
Thanks for the advice, and for asking the moderator to move the message.  Didn't realize that I selected the wrong category, as my eyes were red from trying 100 ways to get it to work.
Message 3 of 5
Easily done. This place is a mess.
Message 4 of 5
tosh30
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1128 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
