Orbi WiFi 7 RBE973
Reply
Installation
Susieann
Installation
A7000 Trying to connect to router need security key, tried both modem & router passwords didn't help set up fine on 1 computer but then asked for security key on next one.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
Retired_Member
Not applicable
Re: Installation
The DEFAULT WIFI security key OR PassPhrase is on the router label UNLESS you changed it.
If you changed it and forgot it THEN press reset until power LED flashes THEN use defaults on the label
Message 2 of 4
All Replies
Retired_Member
Not applicable
Re: Installation
Message 2 of 4
Susieann
Re: Installation
Thanks worked.  Pity these things are not named all the same way for dummy's like me, but it is encouraging to know where to come for the answers.  Thanks again
Message 3 of 4
Retired_Member
Not applicable
Re: Installation
You're Welcome!
Message 4 of 4
Discussion stats
  • 3 replies
  • 2934 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
