- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Instructions to load R8000 Firmware Version 1.0.3.26 (Beta) don't match my genie interface
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Trying to load the latest firmware to fix security issues and the instructions on the firmware page ask me to "Click ADVANCED tab > Administration > Router Update" but there isn't a Router Update option to click.
Current router firmware version: V1.0.0.32 (don't think I've ever upgraded)
NetGear Genie WNDR4500v3
Available options under Administration are - Router Status, Logs, Attached Devices, Backup Settings, Set Password & Firmware Upgrade.
I figure Firmware Upgrade would work but when I try to load the file I downloaded from the instructions (http://www.downloads.netgear.com/files/GDC/R8000/R8000-V1.0.3.26_1.1.18.chk) I get an error stating "Please assign the correct file. The file format is *.img"
Help
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oops, my bad. I was connecting to an old Netgear router in the basement I use as a switch that I had forgotten was there. Once I connected to my R8000 the firmware upgrade went smooth.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Instructions to load R8000 Firmware Version 1.0.3.26 (Beta) don't match my genie interface
DO NOT use the genie app log in to router using web gui @192.168.1.1
I tested it and it worked fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're welcome,
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
