NowRetired's avatar
NowRetired
Internet light on router is flashing orange with no device connected
The Internet light on my netgear router flashing orange.  All my devices are wireless and are not have any connection issues.  Why the flashing orange.  It was not like this before the latest firmaware upate to the router,
  • Well, it fixed itself.  I did not do anything.  It is now blinking white like it use to.  Go figure. Thanks for all the suggestions.
  • > [...] my netgear router [...]
       Does your "my netgear router" have a model number?  Look at the
    product label.  Firmware version?  Connected to what?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Read. Look for the
    LED descriptions and "Troubleshoot".  Further reading might be helpful,
    too.
    • NowRetired's avatar
      NowRetired
      I have a Netgear AC 1750 R6400 router connected to a CISCO DPQ3212 cable modem.  It is running firmware V1.0.1.52_1.0.36 which I just installed about 2 or 3 weeks ago.  I have no ethrnet connections on this router.  I do have about 10 devices connected to the router via WiFi, not all at once..   I have been running all these devices on this router for about 2 years.  The blinking orange light on the internet Led light started after the last firmware upgrade to the router.  There is no impact on any device with this blinking light, it is just a very annoying light.
        NowRetired
