Orbi WiFi 7 RBE973
Reply
Internet speed
cringe91
Follower
Internet speed
Hello, I want to start streaming but my internet speed is slow. I am paying for 50mbps download and 5 upload but I catch around 10-15 download and 1 upload. Will an access point (wax202 ax1800) fix that? Thank you!
Message 1 of 3
schumaku
Guru
Re: Internet speed
Check your Internet connection, the ISP-provided(?) router and Wi-Fi. Have a computer with an Ethernet (1 Gb/s) port and a network cable at hand to run a test.
Tell us more about your Internet connection, what device does make up the Internet, NAT router, Wi-Fi, ...?
Message 2 of 3
Re: Internet speed
Unlikely.
Depending on the quality you want, 50 Mbps is near the limit for streaming.
But, as @schumaku says, you haven't provided enough information to do more than guess what is happening at your end.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 541 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
