Orbi WiFi 7 RBE973
Reply
Is Beta Firmware 1.0.7.6 stable and bug-free?
mzguy
Apprentice
I have an R7000. I know the firmware is in beta. Can anyone chime in with their experiences? Known bugs? Stability? Lost functionality? Cases of successful installation vs. bricking the router?
Can a Netgear representative suggest their level of confidence with this beta, since it apparently was rushed?
Thanks!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 8
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Is Beta Firmware 1.0.7.6 stable and bug-free?
We have a link on the updated Security Advisory to the production firmware.
Message 5 of 8
All Replies
mdgm-ntgr
There is production firmware now.
Message 2 of 8
JohnNadeau
Apprentice
Hey @mdgm-ntgr  ... can you elaborate?  New Version Number... Post about new version?  Thanks!
Message 3 of 8
elcondor
Where?? Is it same number as Beta?
Message 4 of 8
mdgm-ntgr
Message 5 of 8
eurosteve
I updated my firmware yesterday to the BETA version.  It has the same numbers as the "production" version.  Are they the same?  Do I need to redownload and install the production firmware?
Thanks!
Message 6 of 8
IrvSp
Master
They APPEAR to be the same, size at least. Didn't bother to try and binary compared them, just installed it. Works fine after the re-boot it does when installing.
Message 7 of 8
eurosteve
I'm thinking that the firmware didn't change just because they changed the label from BETA to Production, as long as the firmware number stayed the same.  I think they would have changed the number if they did anything to change the firmware as a result of it's trial in Beta.  Does this sound right?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3385 views
  • 1 kudo
  • 6 in conversation
Announcements
Orbi 770 Series
