- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LED Lights Behavior on Ethernet ports changed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a desktop computer connection to one of the ethernet ports on my Nighthawk R6900P router. Up until about a month or so ago when connected and online the port LED would be white & blinking, and when the computer was sleeping the port LED would be a solid amber. Then I noticed that now when the computer is asleep the LED light is not on at all, which would indicate no connection. Functionally or operationally, there is not an issue, I am just wondering why that changed.
Was that perhaps part of a recent security update that turns off the connection to the router when the device is asleep?
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solid amber means the network chip is active at low Mbps. This is most likely for Wake-On-LAN purposes. If you have disabled WoL since then, then the chip will turn itself completely off hence why no LED is shining
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LED Lights Behavior on Ethernet ports changed
That's it!! Thank you!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
