derek42
May 13, 2021Aspirant
MR2 flashing light
When the MR2 is on charging lead only with no battery, is there anyway of stopping the flashing blue light?
It is very annoying when you are trying to sleep in a small motorhome when it is pluged in at the front of the van.
Many thanks.
1 Reply
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but mobile modem/routers are very different from plain vanilla routers, so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
