Orbi WiFi 7 RBE973
Reply
Mac and iPhone dropping Nighthawk X6S connection
chasEgil
The router worked great for 8 months, but then lately there is a delay in connecting my Mac to the router.  Also both the Mac and my iPhone frequently connect to a neighbor's unsecured router.  And my Mac sometimes gives me a message that the stored password is incorrect for making the connection.  It takes a minute of work-around to connect.  2 weeks ago I did pull the plug on both the router and the modem, but after the restart nothing has changed.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 5
Accepted Solutions
microchip8
Master
Re: Mac and iPhone dropping Nighthawk X6S connection
Try a factory reset and reconfigure manually
Message 2 of 5
All Replies
microchip8
Master
Message 2 of 5
chasEgil
Thank you!  I will try that.
Message 3 of 5
chasEgil
Suggested solution has worked very well for 3 days!
Message 4 of 5
myersw
Master
Glad it worked for you.
Properly designed firmware would not require a reset and reconfigure with an update. Suspect you have firmware update on which is the default. I suggest turning that off so you know when update is happening.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1864 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
