Orbi WiFi 7 RBE973
Reply
My Netgear R7000 won't start after power outage
Raflus
I had power issue with my router couple of times do not know why and what was cause. Today I had power outage and router would not switched back on after the restored power. I resolved this by pulling out power adapter from the device and putting it back. Have you ever some of you had something like that? I wondering is it some issue with the router or is it some kind of form of protection from sudden power drop?
Message 1 of 3
Guru
Re: My Netgear R7000 won't start after power outage
Did it restart after unplugging and replugging? It might have been rebooting and gotten interrupted during bootup with another power surge/failure and got it "stuck".
I've seen that happen. Usually killing power or a factory reset fixes it unless something was corrupted.
Message 2 of 3
Raflus
Hi
Thanks for the reply. Yeah after unplugging and plugging in again has restarted. I recall I was doing something with the fuse and it might cause the problem. I will double-check it. Thanks for pointing me in the right direction.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 599 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
