hillbj
Feb 07, 2023Aspirant
My Netgear R8500 can no longer be accessed via url after being switched to AP mode
Greetings, wondering anyone can point me in the right direction and hopefully regain access to my R8500 router. I recently had a 2nd ISP installed at my home so I had to add a dual WAN device which uses load balancing to minimize offline time. A Netgear GS308E smart switch is now in place to hand DHCP duties also manages two VLAN's between many rooms throughout the home. I switched the R8500 over to AP mode, I understand it turns off many of the features which is fine. Previously the url was the standard 192.168.0.1 but now I have no idea how to manage it. It doesnt show up on the DHCP table for the switch either. Is there any way to regain URL access to it while in AP mode?
I have disconnected it from the switch with a laptop wired to the R8500 and no IP was issued for the laptop. Static IP did not work as well. I really cant reset the router to factory as devices in the house are not easily accessible to add it back to wireless.
Any help would be appreciated
You need to find the IP address of the R8500 in AP Mode on the host router that it's connected too. Look at the connected client table on this router for the R8500s IP address and use this address in a web browser to access it.
- hillbjAspirant
unfortunately it is not listed on the DHCP list. Using the mac on the underside as a reference. Used arp -a command and no wireless devices are listed either
Factory reset the R8500 and setup from scratch. Press the reset button for 10 seconds then release.
