Reply
My R8000 is not sending a wireless signal
RossiniL
My Nighthawk X6 does not show up on any wifi lists. When I use a wired connection it works but even when typing in 192.168.1.1 into my browser, I cannot access the settings. I also tried going into my command prompt to find my ip adress and the ip listed there also did not work. It is linked to a Comcast business modem which is in bridge mode.
Message 1 of 7
Accepted Solutions
RossiniL
Re: My R8000 is not sending a wireless signal
How to I perform a factory reset?
Message 4 of 7
All Replies
RossiniL
All of the lights including the 5GHz and the 2.4GHz are on.
Message 2 of 7
Guru
Try a factory reset and setup from scratch using a wired PC and web browser.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 7
RossiniL
Message 4 of 7
Guru
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Message 5 of 7
RossiniL
Thank you so much!
Message 6 of 7
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 865 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
