Orbi WiFi 7 RBE973
Reply
N900
kitty30
Follower
N900
I'm going to relace old N900 with a new Nighthawk soon.
i want to know if I need to uninstall the oldGenie software or and any other files or  software from the old router before I set up neww model?
Didn't see anythng about this other than unplug old router.
Message 1 of 3
Accepted Solutions
Re: N900
No.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 3 of 3
All Replies
William10a
Master
Re: N900
There no files on the n900 router that would just your ssid and passphrease for your wifi and username and password if you want to reuse them using the same wifi setting would save time if you have alot of wifi devices in resetting them when you move the new router.
Genie I'am not sure I do not know what genie your using and what you want to do with the new router.
Message 2 of 3
Re: N900
No.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1822 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
