- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGER AC1200 NOT CONNECTING
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have just purchased the AC1200/EX6120 range extender.
i am currently trying to set this up and bottom line is its not working!
I am in the same room as my router and i have tried the WPS method. I press the button on the extender then on the router, both buttons flash and i never receive a solid green button.
However when i look at WIFI networks i can see both of the extended networks but when i try to enter the right password the device light comes on momentarily goes off then i am told it's the wrong code. That happens on both extended wifi channels.
When i try to use the browser set up, i open the WIFI settings and it does not show me the NETGEAR option to choose and do that way.
please help.
many thanks
Marc
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGER AC1200 NOT CONNECTING
Prior to trying to set it up using the installation assistant, did you factory reset it?
Push and hold reset for 7-15 seconds while its powered on.
Then try using the installation assistant
- Mark as New
- Bookmark
- Subscribe
- Permalink
oh i have only pressed factory rest for a second or two so shall try that.
what's the setup assistant?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its the manual install process. The 2nd video in the series demonstrates using it.
https://www.netgear.com/support/product/EX6120.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh the factory rest button worked and brought up the NETGEAR wifi.
now for some reason i can get as far as putting in the wifi passcode and it just doesn't connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
what router are you connecting it to?
And what area specifically are you talking about? Logging into the extender or actually setting up the routers connection?
- Mark as New
- Bookmark
- Subscribe
- Permalink
it is a technicolour router.
When i am trying to set up the wifi extender, so when it asks me to input the wifi codes for both the 2.4 and 5 channels on the NETGEAR set up website that's when it either kicks me out to the beginning again or says that the password is not correct even though i know it is
- Mark as New
- Bookmark
- Subscribe
- Permalink
any special characters or spaces in the password?
Firmware on the extender?
