Orbi WiFi 7 RBE973
Reply
NIghtHawk R7000 PS4 Nat Type 2
fireblazin
Hello
I had to do a factory reset due to log on issues. That is fixed however since the reset my son cant play Call Of Duty Black Ops 3. The PS4 says the NAT is moderate and it has to say its open to play the game. We have tried all sorts of touble shooting nothing works. Before the reset it worked fine. Can anyone advice on how to fix this? I have checked in the router settings that UPnP is on as someone said it needs to be on it is set to on. What else do I need to do to get the game to work again?
Message 1 of 7
Accepted Solutions
JamesGL
Master
Re: NIghtHawk R7000 PS4 Nat Type 2
Hi fireblazin,
Check for the port number for Call Of Duty and open it under port forwarding.
Message 2 of 7
All Replies
JamesGL
Master
Hi fireblazin,
Message 2 of 7
fireblazin
JamesGL
Thanks...will try that.
Message 3 of 7
JamesGL
Master
Hi fireblazin,
You can check as well under WAN setup for NAT filtering. You may change it to open.
Message 4 of 7
JamesGL
Master
Hi fireblazin,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 7
fireblazin
Thanks to you all I got it to work now.
Message 6 of 7
JamesGL
Master
Hi fireblazin,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 10473 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
