Orbi WiFi 7 RBE973
Reply
Naming 2.4 and 5.0 networks x6s r8000p
Prelector01
Just bought a X6S R8000P router. I currently am using a low-end router that allowed me to name the 2.4 network and password and separately name the 5.0 network with a different name and password. I have about 25 devices now set with the 2.4 name and password. Can I do the same with this unit so I don't have to reconnect all my devices again? If so how do I do this. Thank you and obviously you are dealing with a novice. 76 years old and not a computer guru.
Message 1 of 5
Accepted Solutions
antinode
Guru
Re: Naming 2.4 and 5.0 networks x6s r8000p
> [...] page 55 [...]
   The section "Specify Basic WiFi Settings", yes.
Message 4 of 5
All Replies
labatt
Mentor
Yes you can. Go to this link and put in your model number. Will go to place where you can download the user manual which will answer your questions.
https://www.netgear.com/support/
Message 2 of 5
Prelector01
Thank you for your fast response.  I did look at the manual and it is very confusing.  At least to me.  I think that page 55 is where I should do this but just not sure.  Looking for some gracious person to show me step by step or least tell me what page would show me how.
Stay safe through all this mess and appreciate the comeback.
Joel
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 3 of 5
antinode
Guru
> [...] page 55 [...]
Message 4 of 5
Prelector01
Thank you I will attempt this shortly but not tonight.  Appreciate you taking the time to help me on this.
Be safe and stay well.
Joel
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 912 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
