Orbi WiFi 7 RBE973
Reply
Need help to manually install firmware
slamam1
I tried updating my firmware via a PC browser and it failed.
Now the power light is blinking slowliy and the router is not working.
I have tried searching the netgear website and community and cannot find a totorial on how to connect a PC to the router in order to install the firmware update.
Any help is greatly appreciated!!
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 7
Accepted Solutions
microchip8
Master
Re: Need help to manually install firmware
Message 2 of 7
All Replies
microchip8
Master
Message 2 of 7
One thing to try before you go down the TFTP road as suggested by @microchip8 :
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
There's a faint chance that this will get you into "recovery mode" and can then use the conventional method to upgrade the firmware.
If that fails, then TFTP it is.
Message 3 of 7
slamam1
Thank you @microchip8 microchip8 and @michaelkenward I have tried holding the power button as @michaelkenward suggested which did not work.
I will try the TFTP method and report back.
Message 4 of 7
That reset rarely works for a device that has had a real meltdown in the firmware.
Message 5 of 7
slamam1
The TFTP method worked for me!
THanks @michaelkenward and @microchip8 !
Message 6 of 7
Congratulations. Not the easiest move to make.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1279 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
