Reply
Need to reset my password lost
Jchynes
Follower
Lost my password how do I reset.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Need to reset my password lost
wifi password or login to the router password?
if youi've lost the wifi password, you can always hardwire into the router (skipping needing the wifi password) and view change it under the settings.
If you've lost the password to log into the router and don't know or didn't setup the password recovery feature, then you'd need to factory reset to get back to defaults.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 179 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
