Orbi WiFi 7 RBE973
Reply
Nest Thermostat
ToddPals
Nest Thermostat
I did the MAC lookup and added it as approved in my router but the Nest still will not attach to the R7800 router.  It cannot be this hard...right?  Come on you smart folks out there.....give me the answer I need please!
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: Nest Thermostat
No need to use any MAC filtering with NESTs.
Ive had both of my NESTs connected to my 2.4Ghz radio since day one. I use UpTo300Mb on 2.4Ghz, manual channels 1, 6 or 11 and WPA2 and AES only.
Message 2 of 4
All Replies
Guru
Re: Nest Thermostat
Message 2 of 4
ToddPals
Re: Nest Thermostat
I appreciate your response but I have no idea how to hook it up like you are talking about.  Can you give simple steps on what to do?  I am very much a novice.
Message 3 of 4
Guru
Re: Nest Thermostat
Navigate to your routers web page.
Under the Advanced tab, navigate to Setup, then Wireless setup. You'll find these settings here...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4954 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
