Orbi WiFi 7 RBE973
Reply
Netgear 18
Nuuch
Follower
Netgear 18
Will this handle 200 mb
Message 1 of 5
microchip8
Master
Re: Netgear 18
Which router model? Most current routers don't have issues with 200 Mbps
Message 2 of 5
Guru
Re: Netgear 18
"netgear18" is more than likely  your ssid and not your model.
So as @microchip8 says, what actual model do you have? (look at the label)
Message 3 of 5
Re: Netgear 18
200 Mb what? Wifi? The depends on the wifi client as well as the router.
Message 4 of 5
Re: Netgear 18
model number
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 692 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
