Orbi WiFi 7 RBE973
Reply
Netgear D7000v2 Setup
Jord9857
Hi there,
I followed this - https://community.plus.net/t5/Fibre-To-The-Premises-trial/Netgear-Nighthawk-D7000-V2-VDSL-Set-Up-Ins...
And also used the Netgear Genie 'autosetup' but just can't seem to get the internet to work, it provides the SSID's but no internet 'internet not available'.
I've got the DSL line going straight into the back of the Netgear D7000v2 router DSL port and the lights are glowing white, no orange lights.
I've got FTTC so connecting via DSL port and set to 'Must use DSL WAN' in the WAN Setup > WAN Preference. Set as VLAN 101 as from the Internet Setup as well.
I'm using the DSL email address which we was given on the bottom of the letter from Plusnet which I've put into the field for the ISP details
*******@plusdsl.net and password
I can see on Plusnet forums that others have this router setup so it's not like they don't allow this router. I contatced Plusnet Technicial Support and it's showing the router is active and responding their end as well.
https://imgur.com/a/2r4izcR
https://imgur.com/a/7I72Ocf
https://imgur.com/a/4MQwO8t
Any suggestions will be appreciated, thank you
Message 1 of 6
Accepted Solutions
Jord9857
Re: Netgear D7000v2 Setup
I completely reset & updated to the latest firmware which resolved the issue
Message 5 of 6
All Replies
antinode
Guru
> I followed this - [...]
   An example of a non-DSL connection?  I wouldn't bet on its details
being appropriate.  Have you asked your ISP about them?  The ISP might
also be able to discern what's going wrong.
> [...] the lights are glowing white, [...]
   White DSL and Internet suggest many correct parameters; I'd worry
about the VLAN-related stuff.
Message 2 of 6
All this tells us is that you have problems connecting some unnamed devices to the wifi from your D7000v2. That "internet not available" message may have nothing to do with your modem/router and how it is set up.
We do  not know if you can connect a wired device to one of the router's Ethernet ports. That would conform the state of your Internet connection.
I assume that this is where you found the settings for your service:
How to connect your broadband | Help & Support - Plusnet
Did you try this?
Search - NETGEAR Communities – D7000v2 Plusnet
Finally, you have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
DSL Modems & Routers
Message 3 of 6
antinode
Guru
> devices to the wifi from your D7000v2. [...]
   That's not what it tells _me_.  When did you last see a message like
"internet not available" from a device which was _not_ connected to a
router/WAP?  Hint:
> [...] set to 'Must use DSL WAN' in the WAN Setup > WAN Preference. Set
> as VLAN 101 as from the Internet Setup as well. [...]
   How, exactly, do you believe that that was done?
Message 4 of 6
Jord9857
Message 5 of 6
Could have fixed whatever messed up configuration was in there.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1877 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
