Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk AC1900 Model R7000
Buffalo1438
Greetings all!...
I purchased a Netgear Nighthawk AC1900 Smart WiFi Router just over 1 year ago...I haven't had trouble with it until last night when I simply lost internet connection to all devices in the house with a snap of a finger!.
I now have 2 solid white lights at the far left end of the "lighting bar" that goes across the top front of the router unit....there is normally about 5 white lights on at all times
I have tried all the usual fixes...unplugging router...resetting the router with the reset button...unplugging cable modem...making sure all connections are secure...all good...and I do have an internet signal as I am online now with a cable from my modem directly to my laptop typing this.
Does anyone have any suggestions that don't require an advanced degree...I about ready to just buy a new one.
HELP!
Buffalo1
Message 1 of 3
Guru
Re: Netgear Nighthawk AC1900 Model R7000
Are you able to access the routers web page at 192.168.1.1 with a wired PC and web browser after pressing the reset button for 10 seconds then release?
Did you press the WiFi button on stop of the router for 5 seconds to see if the wifi radio LEDs turn on?
Message 2 of 3
Buffalo1438
Thank you for taking the time to give me a hand...it is much appreciated!...I am sitting down now to give it all a try...I will let you know.
Again...much thanks!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 462 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
