Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk D7000 SNMP support for MRTG
calypso1001
HI Folks
I just replaced my old TPlink 1043ND and 8840T DSL modem with this D7000.  Is there special menu to enable snmp on this modem/router combo.
Below  what I used to get on my old Tplink 8840T.  Everytime I run MRGT config its fails.     Does this DSL modem actually support SNMP?
rgds
Message 1 of 3
Accepted Solutions
calypso1001
Re: Netgear Nighthawk D7000 SNMP support for MRTG
Thanks you are right no DD-WRT for D7000 ADSL/VDSL modem.  definitly not a R7000. Well let see if  a port for D7000 turns up in the database.
Message 3 of 3
All Replies
TheEther
Guru
I never knew the D7000 existed.  Anyway, I think you are out of luck.  I'm pretty sure that SNMP is not supported on stock firmware.
If you had a R7000, you could switch to 3rd party firmware, like DD-WRT, which supports SNMP.
Message 2 of 3
calypso1001
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 9578 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
