Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk R7000
MoniBinis
Follower
bought this device 5 months ago and has been such a disappointment. worked fine, great speeds but out of the blue random reboots, or wifi devices no longer getting internet but devices are connected to wifi of the router.
have tried fw update and didnt solve my problem, have tried fw downgrade and same result. anyone else sees these issues with nighthawk r7000 series?
more importantly, what would you guys recommened for basic home router, with wifi services..went from a linksys to a netgear.
Message 1 of 2
Guru
Re: Netgear Nighthawk R7000
what actual firmware version are you on and what ones did you try?
What modem/gateway is it connected to?
after the firmware changes did you try a factory reset?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 300 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
