Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk R8500 SSID's
kathyspaid
I created two SSID's: BOBKAT and BOBKAT1.  BOBKAT is configured for 2.4GHz and BOBKAT1 for the 5GHz.
All of my PC's show both SSID's in which to connect to the network connection screen except for one PC.
Why is that?
Message 1 of 8
Accepted Solutions
Retired_Member
Not applicable
Re: Netgear Nighthawk R8500 SSID's
If a client can't see 2.4 & 5g it's usually because said client isn't dual band.
Settings are incorrect in the client properties,
Client drivers need updating,
Client cannot receive the selected channel used by the router.
Which Guest .......2.4 or 5g ....... it does make a difference. I'm guessing 2.4 seeing how the guest SSID didn't end in 5g
User error.
Message 6 of 8
All Replies
Retired_Member
Not applicable
maybe it's not dual band
check the settings
Message 2 of 8
kathyspaid
it is actually tri-band.  i think it is setup correctly as the other 3 PC's in my house all show both SSID's (BOBKAT and BOBKAT1). It is only 1 PC that does not.  It only displays BOBKAT.
Message 3 of 8
Retired_Member
Not applicable
I was referring to the 1 client that doesn't see both.
Message 4 of 8
kathyspaid
Thanks for the clarification... The one client that only sees the BOBKAT network can sees the NETGEAR-Guest network.  I enabled that one as a test....
Any other ideas are welcomed.
Message 5 of 8
Retired_Member
Not applicable
User error.
Message 6 of 8
kathyspaid
Thank you.
Message 7 of 8
Retired_Member
Not applicable
You're welcome.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3826 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
