- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear R 7000 Lan Ports not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello who can help
My R7000 does not use lan ports 1 and 3, ports 2 and 4 are working fine.
How can i resolve this
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear R 7000 Lan Ports not working
1. what firmware is on the router?
2. how long have they been not working?
3. if you swap a device onto one of those ports, will it work?
4. what caused it to stop working? (storm, dropped, firmware update, etc)
5. have you tried a simple factory reset and reinstall?
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello ,thanks for the reply:
1. what firmware is on the router? V1.0.11.106_10.2.100
2. how long have they been not working? From day 1
3. if you swap a device onto one of those ports, will it work? Changing has te same effect ,port 1 and 3 don t work, 2 and 4 do
4. what caused it to stop working? (storm, dropped, firmware update, etc) No idea
5. have you tried a simple factory reset and reinstall? Yes no effect
Thanks for your help in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you tried installing the latest 1.0.11.128 firmware for that router?
https://www.netgear.com/support/product/r7000.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Installed firmware 1.0.11.128(rebooted) , still ports 1 and 3 not active
Lan cable active on port 2 switched to 1 and 3 without succes
Please advice
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If this has been going on from day 1, I'd open a support case with netgear.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
sounds like those 2 ports are dead for some reason. You can't really do much to fix them if the ports are technically dead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
